Some fuel consumption figures
MercFan
Hi guys,
Figured I'd post my fuel consumption figures that I took about a week ago.
Engine is a Mercury 1970 1150 1600cc inline 6 two stroke.
Idle in gear - 7 litres/hour
35mph (60km/h) - 12-13 liters/hour
43mph (70km/h) WOT - 22 liters/hour
WOT is around 6000rpm
Running a 15" aluminium prop
Boat is a fiberglass bow rider. Estimated at around 1000kg all up weight.
Silvertip
Re: Some fuel consumption figures
Were those numbers achieved using a fuel flow monitor? If not, I question the accuracy except for the idle figure. I use a flow flow monitor on a 75 HP Merc triple and wide open throttle is 7.5 g/hr vs your 8.7, cruise is 4.5 - 5.0 g/hr vs your 5.8 and idle is .7 g/hr vs your 1.8. Your engine should burn in the vicinity of 11.5 g/hr at WOT and probably 7 g/hr at cruise. If your numbers are correct, you are besting the current crop of equivalent four strokes by a ton so I just question the data.
Yepblaze
Personally I think Silvertip is closer to what I get with mine.
I did pretty good last weekend with a light (throttle-RPM-and load) cruise but that was probably not far off of 7gph
Picture represents another stop before venturing off to next leg of travel.
Scuba Steve
Anyone have burn charts for a late 80's 90 horse 3 cyl. I just rebuilt the carbs and gave her new plugs and I think at a cruise Im burning about 4 an hour. Does this sound close or right?
