1946Zephyr
Thread starter- Joined
- Oct 21, 2008
- 5,556
Well, today, I picked a couple old motors from a guy and they look to be some decent restoration projects. One is a 1955 Johnson 5 1/2hp Model CD-12 and the other is a 1947 Sea King 5hp Model 74GG.
I checked the compression on the old Johnson, after I sprayed the cylinders down with WD-40 and got 70 and 72 psi. I pulled the inspection plate on the flywheel and found a newer set of coils. The ignition has great spark so I bet that I could probably hook up the tank with fresh gas and start it up. The lower unit did have a few droplets of water come out, but all black oil came out after that, so I'm going to flush out the lower unit and put new oil in it with new washers on the plugs and see if that solves the lower unit issue. It shifts in the gears just fine. I'm sure the impeller needs replacing, but I'll fire it up once and see what happens. All the mechanics seem to be there, with the exception of the front faceplate. The high speed needle has been modified and the verticle lever (303468) is home made, but it works just fine. This motor appears to be the in the last few of the CD-12 model, because the engine shroud is the slip off type, like the 1956 and later, rather than the type that has the two wing screws in the front half. Somewhere during the production run in 1955, they did away with the two wing screws and made it just slip off, like the 1956 and later. I'll have to get the serial number off of it to get an idea of when it was built.
The old Sea King needed a shot of WD-40 in both cylinders to clean them out, but now turns good and free. This motor actually looks better than the old Johnson, cosmetically, but it'll need to be degreased. It has one of those cool lookin 5S10 carbs on it, like the typical old Sea King 5hp has on it. I believe this old booger will run like a top. The ignition in it, sparks good, so I think it'll come to life pretty good. I think this old motor has far less hours on it, than the old Johnson and is in much better condition. Once I degrease it, it should actually look pretty darned nice.
Sometime this coming week, I'll fire these motors up and update my post.
