SteveVT
Thread starter- Joined
- Jul 31, 2017
- 163
After repairing the water pump I am getting almost no water to the engine head after starting the motor. I shut down immediately. I let the engine cool removed the thermostat and left the thermostat cover off, to eliminate the thermostat as the problem. I started the engine, and got almost no water coming out of the thermostat inlet (the smaller port side vertical pipe, I assume). Just a few drops. I shut it back down
I imagine water should always flow out of there if the engine is running. I put a garden hose nozzle on that pipe and back flushed it, but there didn't seem to be any obstruction. Trying the motor again yielded the same result.
Here's the repair procedure I used. Please let me know if I did anything wrong or skipped something necessary:
1.) I pulled the lower unit off removed the pump housing and pump plate.
2.) I replaced the upper gear case drive shaft seal under the plate with a new one..
3.) I cleaned the lower water pump plate and pump housing with Xylol
4,) I carefully put 3M 847 only on the contact edges of the gear case casting ridges under the plate
5.) I replaced the plate
6.) I replaced the drive shaft
7.)I put a new woodruff key in the shaft (all new pump parts below, including this one were from a genuine OMC/BRP waterpump kit)
8.)I placed a new impeller on the shaft and aligned with the key
9.)I prepared the pump housing by replacing the shaft seal, and the 2 water tube grommets with new parts
10. I greased the impeller vanes and grommets w/white lithium grease
11.) I put 3m 847 on the contact ridges of the water pump housing, and greased the shaft seal
12.) I slid the housing down the shaft and carefully rotated the drive shaft in a clockwise direction, only, to set the vanes. It rotated without binding.
13. I used new kit screws to fasten the housing.
14.) I added a new rubber O-ring on top of the housing to mate with the lower exhaust housing.
15.) I reassembled the lower unit to the outboard following the manual procedure. The flywheel was ONLY ever turned in a clockwise direction by hand to mate the splines.
Any suggestions why the pump might not be working? Or something I did wrong?
Thanks!
Thanks!
