Solid Riveting, Air Hammer Vs. Riveter
TruckDrivingFool
This is a skill I'd like to pick up, my reply got long, JB closed the old thread, and my thoughts will be heard! :lol:
Because it's long - The short answer yes a $13 HF air hammer will work for most of us since we're looking at doing what maybe 50 rivets in our life time?
I've only ever done swedged/peened solid rivets so I'm certainly no expert just been reading up on it lately and if I'm all wet set me straight, otherwise hopefully this can save someone some time and demystify the air riveter itself and the its difference from an air hammer.
The riveter classification - 1x, 2x, 3x, ect. (I've seen up to 9x listed online but guessing they go bigger) deals with the cylinder and piston size. While the bore I'm sure figures into too for explanation I'm simplifying the numbers and looking at the stroke length.
1x has a 1" stroke thus it will not have the striking force of a 3x with a 3" stroke, however the shorter stroke allows it to cycle faster. Thus you get softer blows more quickly. (this was the hard part for me to wrap my head around)
Solid rivets if hit too hard will work harden thus will not properly set and clinch the material. This means the gun should be matched to the rivet being used. The max rivet a 3x will reliably correctly set is 3/16".
Air hammers seem to fall into the 4x - 5x range which may mean hitting too hard and fast if you you are using 3/16' rivets which could lead to improperly set rivet's that will need drilled out and redone. If you're using 1/4" rivets you're in the right range and is why for most of us "It'll work".
The downside is that while every air hammer I've had has had a variable trigger a riveter adds a regulator to the air supply. This is where control and consistency come in, by being "dialed in" you take out some of the human err that creeps in from how much you squeeze that variable trigger. If we we're talking building airplanes or trailers (the most common DIY solid rivet use I've found on the net) and putting in 1000's of rivets then yes it's worth the money for a task matched gun just in the time saved to get them set correctly the first time. If you're replacing 10 rivets in that old leaky StarCraft well not so much.
All that said I'm going to order the rivet sets and do some practicing with the air hammer I already have out in the garage.
Watermann
I've set 100's of solid 3/16" rivets with my cheap air hammer and set without any trouble at all. Just don't expect good results right off the bat and especially when using solid AL 1100 rivets with no alloy in them. Let the hammer do the work and lay off the bucking bar if using the 1100's.
oldhaven
I just bought a used 4x rivet gun with a lot of different rivet sets, and I was wondering what alloy type rivets should be used to replace the solid rivets in my Starchief hull? Also will this 4x gun be too much force and work harden the rivets as you mention above?
Actually a more general question would be what should I put in stock for rivets for this boat? What sizes, alloys, head types, and what sizes and numbers of clecos should I have on hand for the common tasks of reassembly of stock parts removed during restoration and replacing about 100 through hull rivets? I know you faced a similar situation as I am, so what did you use, and where did you buy them?
That's a lot of questions, so thanks in advance for whatever tech support you can provide.
Ron
Watermann
I will answer your questions as best I can in your thread since your in the rivets there so as to not bump up against and hijack issues.
TruckDrivingFool
Thanks for the tips Watermann perhaps I'll practice with the 1100's, then anything else will be a breeze.
