travisherl
Thread starter- Joined
- Jun 24, 2012
- 26
Re: Solex 44 PA on Volvo aq125
I moved the gasket I cut between the carb and diaphram instead of between the diaphram and pump cover and I'm not seeing any leaks. The diaphram seemed cheap to me - thinner than the old one. So now it's running but the most I can get it adjusted down to is about 1200 RPM and that's with the idle screw all the way out. I'm back to the question of timing and points. Could the timing being off or the points not exactly right cause this? It fires right up and it revs great whether you do it fast or slow. Any ideas?
