Gary H NC
Thread starter- Joined
- Dec 1, 2005
- 8,972
50 hp merc outboard. The solas hub is bonded to the splines on the prop shaft..
Tried the BIG hammer after some PB Blaster with no luck.
Thought of a wheel puller but the thrust washer is rounded on the edge so the 3 jaw puller won't grip it..
Any tricks guys? Tried some heat but didn't want to get it hot enough to damage shaft seals.
Can't believe how cheap the hub is made with the plastic retainer nut...
