Re: So I thought I got a deal.......
Ok guys, been doin work!!! I stripped it completely down to see where the damage lies. I found a bent axle, a replacement leaf actually taller than the original (causing the lean) and rusted u bolts everywhere. I rewelded a few spots that had shotty work from the factory, and ground all the sharp edges round. Gonna order an axle, new pair of matched leafs, 2 new tires/wheels, light kit, make new bunks, and a crank. Before all this stuff gets here, she's gonna get a fresh coat of bright blue paint and grip tape on all the tops of the frame. All in all including the trailer cost, I'll be in a total $550. Not bad for a better than new trailer.
A-Frame Laying flat on my garage floor!!! Straight A-frame
Leading main beam, KINKED 14" from the end. Cut off the kink and now perfect (I had it to spare anyway)
All the usables... Except the crank, getting a new one with nylon strap.
Cleaned up the corners, and primed all the grind spots.
