I was on the lake the other day and after having a problem running at low speeds and the throttle cutting out. Later when I took off the cover, I found out a black vacuum hose going to the carb had come loose. Motor is a 1995 Evinrude Intruder 150hp. I had to keep starting the motor to get back to the dock, but right near the marina I saw smoke coming out by the motor on the last start. After that, it wont turn over at all. I changed the plugs, the flywheel spins without the plugs when I turn the ignition, I just think it doesnt have enough oomph to get the motor to spin. The battery is fully charged.
Any suggestions? What does a new starter/hourly labor run at a mechanic usually?
Thanks.
Thanks.
