boatwaters
Thread starter- Joined
- Nov 4, 2011
- 23
Doing a reseal on an alpha gen ii upper and replacing the bearings on the drive gear as well as shimming (I have all the tools/book etc...). I'm replacing the bearings because they were rusted and you could easily feel it as you spun them. The new set of bearings came with an extra small spacer and no instructions, I don't see this spacer anywhere in the manual. After reading online I found that in some cases I should use it and some not. I unfortunately don't know the model or serial number from the drive but do know that it is a 1991 boat with the original merceruiser engine in it. I am reusing the old gears as they are fine.
If you look in book number 14 on page 3A-24 on the top I have the earlier style where you have to put the hose clamp around the big spacer if that helps.
Should I use this small spacer as well as the big spacer or just use the big one? Thanks.
