Small service
laki101
I have an old 6 hp johnson in pretty ruff shape and i want to do a small service and because I must order them online so i need to make a package so whats the must change stuff on it?
I guess all gaskets , a karb kit , piston ring ( because compression isnt the best), and what else so to make it run good?
tx1961whaler
Re: Small service
What is the compression on each cylinder? 6 HP's usually don't need rings until they have a tremendous amount of hours on them. Does the motor have spark on each cylinder?
Read this first: http://forums.iboats.com/showthread.php?t=158086
Anyway, Here's my list. Everything available at iboats.
Service manual
Spark plugs
Spark plug wires
Coils
Points
Condensers
Water Pump Impeller
Carburetor kit w/new float
Lower end seal kit.
laki101
Re: Small service
So I dont need piston rings ,right? Il check the compression and than make a decision on that. And whats the lowest compression for normal working?
The motor has sparks on both cylinders but weary weak so i guess the spark plug cables , Coils ,Points ,Condensers are necessary.
Impeller was changed 2 weeks ago so no need for that.
I already have an manual for all 2 to 33 hp models so i guess that will work?
And because gaskets arent really easy to find is there any way that i could make my self new ones using so called liquid gaskets ?
And the carb kit has in it what?
tashasdaddy
Re: Small service
laingsoutboards.com should have everything you need.
laki101
Re: Small service
on laingsoutboards usually parts are for 74 and newer outboards and i have a 69 so is that a problem
laki101
Re: Small service
and are points condenser and that in store one so i need to buy 2 of each or a they already packs of 2?
tashasdaddy
Re: Small service
what year is your 6hp? johnson or evinrude? exactly what parts do you need?
laki101
Re: Small service
found everything I need
just not sure about packs of 2 or just one
F_R
Re: Small service
They come both ways. 18-5006 is for two of each and 18-5011 is one of each.
laki101
Re: Small service
And thats here on iboats. But i will buy on laings because on iboat everything is out of stock
