KnotConnected
- Aug 15, 2012
- 221
What you're describing is pretty spot on. The max rpm range for the 454 is 4400-4800. 22.5 pitch prop on a 28 ft boat with a 10 ft. beam, a single 454 and a B3 drive is about right. The numbers and specs are right in line with what I'm getting for the same size and setup. What needs to be tuned is your expectations.
So you're cruising / top speed is roughly the same also?
