Slow crank 74 evinrude 3 cyl.......frustrated!
Ozark74
Long time reader, first time poster.
I have a 1974 evinrude 70hp 3 cyl. that was willed to me. My son and I have been trying to raise it from the dead as a project. We've rebuilt carbs, replaced impeller, new plugs & wires, new fuel lines & tank. We've tried to start motor and we get a slow crank as if it's dead battery or bad starter. I had starter tested (they said didn't have enough torque to spin motor fast enough). We replaced starter and still have slow crank. I even bypassed wiring by putting jumper cables directly on starter and grounding on block. the motor spins freely with plugs removed.
At this point Im looking for any advice.
Chris
wifisher
Re: Slow crank 74 evinrude 3 cyl.......frustrated!
The only thing that I see that you missed is the battery condition. How old is it? Have you load tested it?
D
DJ
Guest
1. Disconnect the battery.
2. Remove the negative battery terminal form the engine block and clean thoroughly.
3. Reconnect and reconnect battery.
Ozark74
In testing the motor I was actually using jumper cables from my car battery. I hooked them directly to boat positive and negative leads on boat. When that didn't work I bypassed leads on boat tand grounded to the block and. Positive right on starter lead. Same problem exists. Would an active car battery in your daily driver not be strong enough to crank my evinrude?
wifisher
Your car battery is plenty strong to crank the boat motor, but you jumper cables may not have been capable of carrying enough current. There could have been a bad connection on either end, or a bad cable.
Remove and clean all battery cable connections, and load test your battery.
D
DJ
Guest
It should, that still may not be allowing a good connection.
ledgefinder
Ensign
Jumper cables are absolutely not enough. You need a solid, clean bolted connection with a heavy-gauge electical cable, for both 12V and ground.
Not sure why OMC starting systems are different from a typical automobile starting system, that way. But I've seen it again & again. Have picked up at least two good motors, cheap, because seller thought compression was low, when all it was was slow cranking due to poor connections. Seen people buy new starters & solenoids ($200), then give up on the motor in frustration, when all it was was poor connections.
Fed
2 minutes with a voltmeter and someone to turn the key would answer all your questions.
Bob_VT
Examine your cables and wires. Corrosion inside the casing is not uncommon. When you get corrosion it robs you of voltage.
Every wire and cable needs to be inspected. Every connection needs to be removed, sanded off with sand paper and re-installed tight...... this includes the starter mounting tabs.
Ozark74
Thanks guys . put new cables and battery in it and it fixed the problem. Now motor cranks normal, but doesn't even come close to starting. Checked fuel and we are good there. However, tested spark at plugs (no spark at all three cyl.). Any suggestions as to what to check first?
