Sloppy Gimble Ring
spydermann11
I am replacing 3 Bellows and Gimble Bearing on an 1987 Alpha 1(1) and the Gimble Ring seems to have a lot of play.
Side to side (turning) and verticle (up and down on the swivel pins).
On the swivel pins, I can move the Gimble Ring up .090" from where it is resting.
I can turn the Gimble Ring a couple degrees each way.
How much is normall or acceptable?
Can I shim the lower pivot pin (under the Bimble Ring)?
Haut Medoc
Re: Sloppy Gimble Ring
Did you try torquing the two bolts on the top of the gimbal ring to 55#?...:confused:​
spydermann11
Haut, I have not tried anything to this point. It sounds like you are talking about the bolts that clamp against the square upper pin?
Haut Medoc
Yup.......;)
Another place would be where the steering arm meets theupper shaft....
As far as the up & down play, I forget the tolerance of hand, but it is small....
I would try shimming as a last resort after everything else has been tightened up.....
I don't see why you could not shim it if done properly, but be real careful removing that lower pin, if you break the casting, you are in for a new gimbal housing......:(
I'm thinking that if everything else is tightened shimming won't be neccessary....;)​
spydermann11
Thanks Haut. I appreciate the advice and will give it a try.
spydermann11
I finally got to tightening the bolts against the square upper pin. You were 100% correct. They were not clamping the pin at all, the bolts were basically sitting there for show. I now have almost 0 side to side (turning) slop. This will be a great improvment for wandering!
I do still have .090" of play vertically. When the ring is sitting (relaxed), I can move it upward with no pressure. Is this a problem that I should dig into or not a big deal?
