Slight growl from Penta DP-SM drive
Lupus
Hallo,
I have noticed a slight growl from my drive when in neutral. However when I apply forward or reverse gear it stops and no noise is detected. Can anyone tell me if I should consider water intrusion in the bellow (immediate action required) or most likely just a bad gimbal bearing that needs replacement in 2-3 months when I make my winter storage. My boat remains in water until October so I will not have access to removing the drive to check unless I bring her up. What would you guys recommend ? - Thanks for feed back.
bruceb58
Re: Slight growl from Penta DP-SM drive
I believe this is normal. Mine does the same thing. When the upper gears are not loaded they will make this noise.
Don S
When was the last time the bellows was replaced, and how long since the drive was actually removed to inspect things?
Lupus
In fact the two bellows was changed April 2008.
At that time I had the gimbal bearing/ seal changed as well but I realized during the work that my mechanic (being a VOLVO guy though!) had difficulties pushing the drive in place (after reading several threads this last winter I found that this means the alignment is not correct!). I had no noise last summer and put 40 hours to it.
This spring I had the drive off again to lubricate and check for water. All looked good ... beside the alignment which was off. Anyway after inspecting the u-joint I did not notice any damage to the teeths going into the coupler and the u-joint itself still looked good with no tolerances. I had the alignment corrected by the proper tool and put all back in place. However hereafter I had the slight growl when the gear is not engaged. I am wondering if the bearing (even I could not feel it during my inspection this spring) may have been damaged a little last year due to the wrong alignment and therefore now is a bit loose and causing the growl.
