Skeg and gearcase crack Fix
osito2789
https://drive.google.com/open?id=0B3dyjVyh6WiXVXVwS3NoTVJLWkE
Hello,
I have a bow rider, Mercruiser 200/V8. Last weekend, cruising around 45-50mph I hit a rock or something, did not see white warning buoy due to passengers in the bow seats.... ..
At the moment I thought no damage to drive was made as the boat kept driving fine for for onether two hours at same speeds.. We pulled of the lake at night so did notice the broken skeg when trailering boat.... ..
Few days later when inspecting boat, i saw the broken skeg. And notice the gear lune dripping.
It broke the skeg pretty bad and looks like it knocked a hole or crack in the backside of gearcase. but the gear lube is just dripping out.... ..
The whole drive unit is brand new, i just replaced last fall with one of those Sterndrive engineer.. and it been working great.. ..I drop the boat at the shop today so they can tell me what options i have to fix it... ...
But i need advices from you guys that been thru this before. Im sure mechanics will try to make me replace lower unit. I cant afford to replace lower unit this year, Or remove the lower unit for rewelding.. ..
So i need i temporary fix..
Im thinking draining gearlube, then sanding the area and use JB weld/epoxy to fill the hole.. and then use a skeg gaurd. As i read in another post.
I attached pictures folder link from google drive.. Couldnt upload here cuz it said size was to big.
You can see there is some kind of transparent glue/silicone on hole. What is that?
And would i be able to fit a skeg guard on mine?
Skeg guard i have in mind::
https://www.amazon.com/dp/B004HYEAQK/ref=cm_sw_r_cp_api_05R3ybA2NSTAV
I will really apreciate anyone help!!!
tpenfield
That sort of fix will certainly be temporary, no doubt about that. I am thinking that based on the severity of the impact, the outdrive may destroy itself given a little bit of time.
Nope,.... I ain't seein' that,....
Ayuh,.... You can Try it,.... Donno's it'll hold up, or not,....
crazy charlie
a temp fix may be a recipe for disaster if it fails.It really depends where the track/hole is .If you are going to attempt to temp repair it,you are going to have to remove all gear lube so you can attempt this with a clean non leaking/seeping crack.IF you are able to get it that way,spray the heck out of the damage with a can of brake cleaner to remove all oil and residue.If it is still not leaking/seeping,sand a good size area with coarse sand paper.Maybe run a rotary wire brush into the crack.Spray some brake cleaner again and finish with wiping with acetone.I would use marine tex or JB weld and start by forcing it into the crack first and follow up with covering an area approx 2x the size of the crack.A heat lamp will help it cure since there will be an issue with the product sagging as it sits to dry.You can wet your finger and manipulate it into place if it is not too tacky.If you get it to dry correctly in place,after 24 hours I would sand it rough and extend onto the bordering metal and follow up with 3m 5200 on top of the repair which will hold the marine tex in place. If it should happen to fail.Make sure to get enough of the bordering metal sanded/cleaned up so there is ample metal for the 5200 to hold onto.Same sagging issue unless you use the fast curing type.As I stated a temp fix may be a recipe for disaster and I dont recommend BUT if you are going to anyway,the method I described will give you the best shot at a successful temp fix.Just dont forget that it is TEMPORARY.I still dont recommend it.Good Luck and keep us posted!! Charlie
osito2789
Thanks charlie. By Disaster you mean the lower unit failing?
km1125
Now, that just sounds kinda funny coming from a guy named "Bondo"!!! ;)
On a serious note, you could use some of the low-temperature aluminum "brazing" rods. I think harbor freight carries them
You'd have to drain the lower unit, clean as much as you can and maybe grind a little groove into the crack. Then you use something like a MAPP gas torch to get the aluminum "brazing" rods to melt in there and bond with the aluminum.
Rick Stephens
What coverage comes with 'no-fault' SEI warranty? Probably not impact damage. But I would certainly advise you ask Justin (justin @ sterndrive dot cc), the tech at SEI, what he thinks. Send him photo link and everything. Maybe he can make a deal on a case or rebuild for less than you might think. Might save you $700 bill next month.
dingbat
Pull the bearing carrier and take it to a local shop and have it welded.
what dingbat said
those low-temp aluminum brazing rods are a hit-n-miss repair that I have never had last.
however a good bead of weld dime-rolled by a tig torch, a bit of grinding, etc. and your good to go.
Rick Stephens
Can't disagree with the weld job. Must be disassembled and clean as new. Surest way to goober aluminum is weld with any oil present. TIG is the right way.
gm280
My .02 cents worth. Absolutely remove the unit, disassemble it, clean it, clean it again, and clean it once more. Then take it and have it welded properly. Anything else is a huge gamble in my opinion. I realize that isn't the answer you are looking for, but that is the best option to save the unit and you money as well. JMHO
bman440440
FYI here is the warranty info...
1. WARRANTY. All products sold by Sterndrive Engineering (?SEI?) are warranted for either a period of one (1) year or three (3) years from the date of actual purchase. A condition precedent to the enforcement of these warranties is proof of purchase of the SEI product. Satisfactory evidence of purchase must be supplied by customer prior to receiving warranty benefits hereunder. These one (1) year and three (3) year warranties against defects in material and workmanship are the sole and exclusive warranty provided by SEI and all other warranties and potential damages are limited and excluded hereunder, as set forth below. These warranties commence on the shipment date of products sold by SEI to purchaser or upon the date of purchase from a properly authorized SEI dealer to its customer. 2. WARRANTIES LIMITED TO MANUFACTURED GOODS. SEI offers a three (3) year fault free warranty on assembled sterndrive halves (upper and lower) and on outboard lower units (OLUs) and a one (1) year warranty on all other parts. These warranties do not apply to any repairs, alterations, or work undertaken by third parties not involved in the actual manufacturing of the product. SEI's three (3) year fault free warranty covers any failure that would require repair or replacement. SEI's one year warranty does not apply to damages or problems caused by removal of parts, adjustments to the product, tune ups, normal wear and tear, damages caused by accidents, improper use of the product, improper installation or service of the product, misuse, neglect, improper maintenance, or operation with fluids, fuels, lubricants, oils, or other such items which are not suitable for use with the product or otherwise not recommended for the product by SEI. SEI's one year warranty also does not warrant or make representations with respect to installation errors, work by servicing dealers, servicing mechanics, or others, and does not cover damage caused by acts of God, flood, fire, storms, or other natural acts or disasters. Both warranties specified herein are null and void in the event that the model number and other identification numbers on the product have been altered, defaced, removed, or eliminated or the product has been disassembled in any manner with out prior authorization by SEI. Neither one (1) year nor three (3) year warranty covers use of the product for racing or other competitive activities. The manufacturer offers no warranty with respect to the rental or use of the product for commercial purposes, or in the event of intentional destruction, or in applications exceeding horsepower limits stated by SEI.
3. EXCLUSION OF OTHER WARRANTIES. THE WARRANTIES OFFERED BY SEI AGAINST DEFECTS IN WORKMANSHIP AND MATERIALS ARE THE EXCLUSIVE WARRANTIES OFFERED BY MANUFACTURER. ALL OTHER WARRANTIES, WHETHER EXPRESS OR IMPLIED, INCLUDING, WITHOUT LIMITATION, IMPLIED WARRANTIES OF MERCHANTABILITY, AND WARRANTIES FOR FITNESS FOR A PARTICULAR PURPOSE, ARE HEREBY EXCLUDED. SEI OFFERS NO WARRANTIES WHICH EXTEND BEYOND THE DESCRIPTION ON THE FACE OF THIS DOCUMENT. EXCEPT AS PROVIDED HEREUNDER, ALL EXPRESS AND IMPLIED WARRANTIES, OF WHATSOEVER NATURE, INCLUDING WARRANTIES ARISING UNDER THE UNIFORM COMMERCIAL CODE AND UNDER STATE AND FEDERAL LAW ARE EXCLUDED. SUBJECT TO THE ONE (1) YEAR WARRANTY HEREUNDER, PURCHASER ACCEPTS THE PRODUCT ?AS IS? AND ?WITH ALL FAULTS,? AS MAY BE THE CASE. SEI MAKES NO WARRANTIES, GUARANTIES, OR REPRESENTATIONS REGARDING THE RELIABILITY OR USE OF THE PRODUCT EXCEPT AS SET FORTH HEREUNDER.
4. LIMITATION OF DAMAGES. SEI SHALL NOT BE LIABLE TO THE USER OR PURCHASER OF ITS PRODUCTS, FOR ANY INCIDENTAL, CONSEQUENTIAL, OR SPECIAL DAMAGES OF ANY TYPE. THE EXCLUSIVE REMEDY TO THE USER OR BUYER, AND THE LIMIT OF LEGAL LIABILITY OF SEI HEREUNDER, SHALL BE THE REPLACEMENT OF ANY DEFECTIVE PARTS OR THE REPAIR OF ANY AND ALL DEFECTIVE MATERIALS AND WORKMANSHIP. REPAIR OR REPLACEMENT OF DEFECTIVE WORKMANSHIP AND MATERIALS SHALL BE THE EXCLUSIVE AND SOLE REMEDY PROVIDED TO USER AND/OR PURCHASER. UNDER NO CIRCUMSTANCES WILL SEI OR ITS DIRECTORS, OFFICERS, SHAREHOLDERS, EMPLOYEES, OR AGENTS BE LIABLE TO PURCHASER OR USER FOR ANY SPECIAL OR INDIRECT DAMAGES INCLUDING DAMAGES FOR THE LOSS OF BUSINESS PROFITS, BUSINESS INTERRUPTION, PERSONAL INJURY, AND GENERAL COMMERCIAL DAMAGES, INCLUDING ALL LOSSES ARISING OUT OF THE INABILITY TO USE OR OPERATE THE PRODUCT.
SEI MAXIMUM LIABILITY TO USER OR PURCHASER, FOR DAMAGES OF ANY NATURE, REGARDLESS OF THE TYPE OF CLAIM, INCLUDING BREACH OF CONTRACT, NEGLIGENCE, PRODUCT LIABILITY, TORT, OR OTHERWISE, SHALL BE STRICTLY LIMITED TO THE PURCHASE PRICE SEI PRODUCT. ALL WARRANTIES PROVIDED HEREUNDER ARE GRANTED SOLELY BY SEI AND NO MODIFICATION OF THIS WARRANTY SHALL BE VALID, UNLESS REDUCED IN WRITING AND APPROVED BY THE DIRECTORS OF SEI. NO THIRD PARTY, INCLUDING DEALER, SERVICE AGENTS, WORKMEN, OR THE LIKE MAY MAKE ANY ACTUAL OR IMPLIED MODIFICATION, EXTENSION, OR REVISION TO THIS WARRANTY PLAN. THIS WARRANTY IS INTENDED TO LIMIT THE RIGHTS OF ANY USER OR PURCHASER TO THE ONE (1) YEAR WARRANTY SET FORTH HEREIN AND SHALL BE STRICTLY CONSTRUED TO ACCOMPLISH THAT OBJECTIVE.
Bt Doctur
Disassemble and weld it this is the best or replace the lower case
Grind the area , clean well, plumber epoxy putty, fiberglass resin and cloth Use this as an emergency fix to get home.
tank1949
Depending on how close to seals???? drain gear lube for a day. use brake cleaner to clean aluminum crack. let cleaner dry. spray AGAIN and let dry. Use air grinder to grind out a TIG canal (just enough depending on crack size). Spray and dry again.TIG it. keep a wet towel near by to keep TIG temperatures reasonable not to melt seals. This can be touch and go. Ideally, OD should be on side to make sure TIG fills crack. Pressure test! Go boating.
Faztbullet
Press Release -- September 18th, 2006
Sterndrive Engineering Adopts Three Year Fault-free Warranty
Clearwater, Florida -- Sterndrive Engineering Inc. (SEI) announced today that the warranty on it's sterndrives has been changed from a one year limited warranty to a three year fault-free warranty. "We believe this new warranty is the best in the sterndrive industry" said Greg Pickren, President SEI. "Nobody that we know of offers a three year fault-free warranty on sterndrives" he added. "After selling tens of thousands of these drives over the past three years and doing extensive testing at our research facility, we are very confident in the product. It's only natural at this point to extend our warranty?€? stated Justin Webb, SEI's General Manager. "Our drives have always been the most economical. Now they also have a great warranty." added Ericka Kegg, SEI's Sales Manager. The three year fault-free warranty covers any damage to the drive that requires it to be repaired or replaced including failures resulting from lack of oil, fishing line, impact, neglect, and other abuse.
Sterndrive Engineering is the largest aftermarket supplier of sterndrives in the world. For more information on the company call (727) 461-0811. For more information on the new warranty policy and online shopping visit www.**************.
osito2789
You was so right. I email with details and pictures, and called them too.
Surprisingly this impact damage is cover by warranty.. my mechanic is droping the lower unit and sending it back for replacement.
Awesome. Thank you guys!!!
Ayuh,.... Ya Gotta Love those folks at SEI,....
