https://drive.google.com/open?id=0B3dyjVyh6WiXVXVwS3NoTVJLWkE
Hello,
I have a bow rider, Mercruiser 200/V8. Last weekend, cruising around 45-50mph I hit a rock or something, did not see white warning buoy due to passengers in the bow seats.... ..
At the moment I thought no damage to drive was made as the boat kept driving fine for for onether two hours at same speeds.. We pulled of the lake at night so did notice the broken skeg when trailering boat.... ..
Few days later when inspecting boat, i saw the broken skeg. And notice the gear lune dripping.
It broke the skeg pretty bad and looks like it knocked a hole or crack in the backside of gearcase. but the gear lube is just dripping out.... ..
The whole drive unit is brand new, i just replaced last fall with one of those Sterndrive engineer.. and it been working great.. ..I drop the boat at the shop today so they can tell me what options i have to fix it... ...
But i need advices from you guys that been thru this before. Im sure mechanics will try to make me replace lower unit. I cant afford to replace lower unit this year, Or remove the lower unit for rewelding.. ..
So i need i temporary fix..
Im thinking draining gearlube, then sanding the area and use JB weld/epoxy to fill the hole.. and then use a skeg gaurd. As i read in another post.
I attached pictures folder link from google drive.. Couldnt upload here cuz it said size was to big.
You can see there is some kind of transparent glue/silicone on hole. What is that?
And would i be able to fit a skeg guard on mine?
Skeg guard i have in mind::
https://www.amazon.com/dp/B004HYEAQK/ref=cm_sw_r_cp_api_05R3ybA2NSTAV
I will really apreciate anyone help!!!
Hello,
