Fisherball
- Mar 19, 2009
- 470
I started it. After 4 years of good use my $100.00 16' 1975 MFG bowrider is rotted. I was going to put a casting deck over the bow seats & discovered when I pulled the butt seat from the front deck that a big piece of the deck just broke off with the pedestal.
I cut a hole between the front seats & found that a PO had covered the deck with bare, untreated 3/4" plywood. Everything under the deck was rotted & the foam was soaked. Water sqeeezed out of it like a sponge.
This site taught me what I have to do. Stringers, deck & transom. I derigged it & stored the parts in labelled bags in my garage. Disassembled the windshield. I can reuse almost all the parts.
I pulled the motor & put it on a stand. The last 2 times out I noticed a noise like a valve tap but 2 strokes don't have valves that tap. Piston slap, a bad ring. So when it's too cold to work on boat, I'll be rebuilding motor. It's a 1981 70 hp Johnson that until now always ran great. Never turned over more than 3 times without starting unless I flooded it.
I've been reading these threads for over a year & think I can do it. I'm pleased with the knowledge I've gathered here & am sure I will be asking questions & reading even more. Any or all help will be greatly appreciated. I started the restore in July, I'm taking my time cuz I'm really busy with work yet money is tight. Itchy forearms come from my first real grinding this weekend but I'll build this thread in the order it happened.
Here's a link to my Photobucket album on the restore if anyone cares to look.
http://s789.photobucket.com/albums/yy173/Fisherball1/MFG Restoration 7 4 10/?start=all
Thanks for reading.
Thanks for reading.
