siphoning fuel from gas tank
Hi. I have a 1997 Lowe Silhouette deck boat that has been sitting since February due to medical issues. I want to siphon out the fuel (3/4 tank full) as it will probably be spring before I can take the boat out again. My problem is I can not get the fuel to flow trying to siphon. I have used two different types of pumps an nothing comes out the hose even though plenty of hose is wet with fuel. Do I need to pump fuel out through the fuel line going to the motor? Thanks for any advice.
mike_i
Did you treat the gas with a stabilizer in February? Where are you trying to pump from? Can you access the tank to remove the sending unit and pump from there?
I am trying to pump from the filler tube. I did treat the fuel with a heavy dose of Stabil Marine fuel stabilizer. Treated for a full tank not realizing it was 3/4 full. I can access the sending unit. Didn't think of that. Do you think the Stabil will keep the fuel usable until @ February or March?
robert graham
Get a sample of the gas in your tank and smell of it and look at it…if it smells and looks O.K. Then it’s probably fine…especially since you treated it with Stabil….
no way to get any siphon valve down the fill neck. most do a 90 degree at the tank.
either pull the Anti-Siphon valve and replace with normal fitting and use the pickup tube, or remove the sending unit and siphon from there.
The best way to siphon the fuel is to remove the fuel gauge sender and put a piece of 1/2" copper pipe in the end of the siphon hose. Now stick the pipe thru the garboard drain and into a jerry can, and start the siphon.
Lectro88
This is outside of the box. and some trouble.
You could disconnect fuel line at motor and fire up and run a minute on TruFuel. That should for sure save your carbs.
I am not a fan of Eth. sitting.
However you may be Ok with a strong dose as you described.
JASinIL2006
I’d leave it. Treat it with some more Stabil if you’re really worried about it. Fears of ethanol are greatly overblown.
hugh g
As long as you ran the engine for a few minutes after adding Stabil you should be fine, imho.
My carbs are dry. They drain when the motor is tilted.
My concern has been for the stability and octane rating of the fuel in the tank remaining viable. The carbs are dry as they drain when the motor has been tilted for about a week.
