Single Crank Mercruiser 4.3
chewy51
Went out to the lake this weekend and boat wouldn't start. Had is started in the driveway the week before. Troubleshooting and reading through the forums tells me I have a connectivity issues, battery, starter or solenoid problem.
Symptoms: Boat turns over with single crank each time. Sometimes it grinds after the single crank sometimes it spins. I have checked and tightened and cleaned all the connections. Today was able to start it but once again only on a single crank. If it catches great but I can still tell there some type of power starter issue. What is the best way to tell where I am failing. Can I test the connections with multi-meter or something?
Any other ideas what could be happening? Thanks David
chewy51
I failed to mention i put another battery in there from my tractor, same results. Thanks
You should repost in the I/O section. Sounds like a timing issue, but I am not sure what you mean by "single crank". You might define it better.
chewy51
Not sure why it would be a timing issue, it started yesterday and ran great. Not sure another way to say single crank. Dictionary defines crank below. So one revolution(crank) then the starter spins or grinds.
crank[SUP]1[/SUP]
kraNGk/
verb
[COLOR=#878787 !important]
  • 1.
    turn the crankshaft of (an internal combustion engine), typically in order to start the engine
[/COLOR]
