Simple Question.. Thermostat location????
Pbdy Jr
I have A mercruiser 3.7 165 i/o s/n B516408 I bought this off a dirty seller and have done soooo much to it. i now hit it running and going into gear and shifting properly, but it overheats. I pulled all hoses to the heat exchanger and cannot locate a thermostat anywhere. Where should the thermostat be so I can put one in and see if that solves my issue.
stonyloam
Re: Simple Question.. Thermostat location????
Have you changed your impeller in the outdrive? If not that is the first thing you need to do. The thermostat is one of the less likely things to go wrong, behind impeller and restricted water flow through the exchanger.
