Should water be coming out here?
71erude
I'm dealing with an overheat problem. I think the water tube to powerhead connection is leaking. Unless I misunderstand something. With a garden hose attached to the water tube should any water come back down through the opening at C in the picture?
Fisherball
Re: Should water be coming out here?
Not sure about your motor but on my 1981 Johnson 70 hp the discharge from the motor comes out a small grommetted hole up near the top where the cowling attaches, on the port side of the powerhead. I think most outboards do this so you can see if your motor has water running through it as you cruise. The underside of my motor looks almost exactly like yours. Best bet is to buy a manual that will explain everything in detail. Mine cost $30.00 & saved me $300.00 first time I used it.
P.S. I am not an expert!
