Should this be rubbing on my 92 25hp merc 2stroke
971500
It sticks at wot when cycling it while not running sometimes . just does't seem right. runs fine. never knew it to stick while running.
1nebel0
No it should not be rubbing... my son has a 25hp on his mini boat... I will check it... how about moving the rod to the outside on the bracket moving..Not the stator connection.
971500
Thanks. I looked more into it. The brass rod has a slight bend in it and the lock nut was loose cause it to twist and rub. Turned brass rod 180* and tighten nut now it's no where near the block. The bend in the rod was just positioned wrong. I just hope by turning it I didn't mess up the timing.
