Should I go one pitch larger?
briggs09hp
Hello,
I have a 1995 Sea Ray Signature 200 cuddy. It has a Mercrusier 5.0 (2bbl 190 HP) and Alpha 1 outdrive. The boat weighs about 2900 lbs and I think the prop that I just had my mechanic put on is a 14.5 x 21 pitch. I had him put on a prop with more pitch because the old SS one was bent and I was also over revving. From my understanding the WOT RPM is about 4300-4600 RPM for my boat.
I just took the boat out today for a test of my new prop. The lake was nearly glass so it was very smooth (no wind). I took the boat both up and down the lake to take the current into account, but both runs were the same.
I ran a top speed of 48 MPH on the GPS at 4700 RPM trimmed almost all the way out. So my question is, should I go to a 22 pitch (one size larger)? I heard that every pitch size changes RPM by about 200 RPM, so I am thinking that would put me in the correct RPM range. Would going 1 size larger increase speed slightly? I am thinking if the engine has the power, it should be able to? Is 48 MPH fast, or about normal?
I am looking for speed and understand that I will lose some acceleration by doing so. When I tested the boat it was just me and my gear on board and a half tank of gas. I know if I put more people on I would slow down, but am I doing it correctly? Do you want to test props fully loaded, or the way I did it?
I feel like I'm right at the limit, and Im not sure what to do.
Thanks,
Matt
Glasply
Re: Should I go one pitch larger?
4700 seems like a solid WOT rpm. I wouldn't run my boat that fast for long, but it's a decent redline for a small block chevy. IMHO I wouldn't prop any bigger, you'll lose too much on the hole shot. It's no fun making everybody scoot to the bow to get on plane.
Tig
From where you, are any increase in speed will imperceptible even if it can be measured by GPS.
Loss in acceleration is generally much easier to notice.
I think it makes more sense to test with a typical load and typical conditions.
I wouldn't go up but I guess it all depends on what you want. I'm propped to over rev if wide open with a light load, so I don't go wide open with a light load. When I do carry a capacity load the acceleration is still acceptable. My preference is to be a tad slower on the GPS when I'm alone as opposed to being an obvious slug with a boat load of friends and family.
I'd load her up to capacity and go for a spin. See how she works just for reference sake.
You probably have more than enough pitch. IMO
craze1cars
Leave it. You're good. I believe you will regret going to a larger pitch and wouldn't gain any speed. And I wouldn't even bother to be careful with light loads because occasional blasts of 4,700 rpm will never harm that motor or outdrive...it's far from an "overrev" situation, and being a hair above your range will really benefit you in daily cruising and holeshot. And when you add a little chop and a little more weight, you'll be absolutely perfect. IMO 48 mph is pretty good speed for a boat of that age/motor/design/size.
