Cali_Boat_Guy
Thread starter- Joined
- Jun 7, 2022
- 82
Thanks again! I appreciate the advice.Yes. I have the same one. I seal the backside of a hole with plumbers putty, then good plastic on the side where you attaching the hose to the pump. Depending on the moisture level in the wood, I’ll sometimes add a secondary catch can so the moisture doesn’t get to the pump itself. Seal all hose fittings with the plumbers putty and give it a go.
