Short shaft availability....or long shaft to short shaft conversion
Tim Frank
I repowered a 1950s Orlando Clipper tinny from a 1968 55 HP Johnson to a 40HP Nissan.
At the time that I bought the motor it was the most HP in a short shaft that I could find.
I hadn't found this website yet so all the research and options were what I found myself. I was hoping for a 50HP SS but 40HP was as big as I could find.
Although it is too late and i don't need to change anything now, I have wondered, and might as well ask....
Would it have been possible and/or feasible to convert from a 50 HP log shaft to a short shaft?
TOHATSU GURU
Re: Short shaft availability....or long shaft to short shaft conversion
The 40 and 50 are the same engine so..........
Tim Frank
Arrrrrrrrrrggghhhh....I think....:eek:
So the extra length is probably an insert piece that could have been removed if I had bought the 50HP long shaft and the drive shaft would have had to be replaced?
It likely would have been more $$ than I would have wanted to spend at the time.
What is the actual difference between the 40and 50 that give it the extra 10 HP?
TOHATSU GURU
"So the extra length is probably an insert piece that could have been removed if I had bought the 50HP long shaft"
No, the intermediate motor leg would have to be changed out as well as the water tube, shift rod and drive shaft. Around $700.00 in parts.
Depends on which series of 40/50 you have. All have the same leg system, but, some have different carbs and exhaust pipes, some have different blocks and cranks and some have different ECUs.
Tim Frank
It's a 2005 Nissan 40 HP 2-stroke
TOHATSU GURU
Years don't mean anything and aren't used. It's all about model and serial number.
Tim Frank
It's an NSD-40.
TOHATSU GURU
If you have a TLDI then the ECM would have to be changed.
psteurer
Hmm, can you mount the motor 5 inches higher on your transom? That is a quick fix to convert a long shaft to a short shaft. I have seen this done but do not know the effect on performance. Just thinking about it, I can not see any effect other than appearance.
Tim Frank
It would raise COG too much.
The 40 HP is a perfectly good match for the boat, and the Nissan is a sweet motor.
I was just curious whether i missed any options, and if by some miraccle and alignment of stars and moon I could buy parts to upgrade it to 50 HP for a few hundred $$$ I would probably consider it.
TOHATSU GURU
Then you don't have a NSD40...So, what do you have?
pvanv
Sounds like you have the NSD40, which is a TLDI. To upgrade to a 50, you would change the ECM.
Tim Frank
OK, NOT NSD40, it's NS40D
TOHATSU GURU
A 40 D could be either a block, crank, carbs and pipe change or just a carbs and pipe change. Depends on the serial number.
Tim Frank
Is this the serial number or just full model # => NS40D2EPT01
TOHATSU GURU
That's a model number...It also means you need three new carbs and an exhaust pipe to turn it into a 50 if your serial number is 47846 or higher.
