shorelandr trailor
enjoynlife2
i live in N,Y and i just bought a 1979 mark twain 24 foot boat and with a shorelandr tralor my queston is can any one tell how to find the vin for trailor or if by chance how much it weighs it is about 30 feet long and duel axle
Bob_VT
Re: shorelandr trailor
Welcome to iboats.
My guess is around 1100-1200 lbs empty.
Shorelaner has a good web site where you can look up specs.
The VIN is on a tag either on the tongue or at the back of the frame rail.
nlain
My 04 Shorelandr has the vin on a sticker on the inside of the left frame rail near the front. I know mine is a lot newer model than the one asked about but it is another place to look.
enjoynlife2
Well i did find the sticker or plate for my shorelandr trailor it was on the right side if your facing the tounge shows weight and not shur about the vin tho they say it should be 17 letters but this is only 6 on my trailor it is a old trailor mfg is 1978so i called a distrabutor and they gave me a 800 num. For shorelander will let all no how it turns out cause by my luck there closed for the 4th holiday until tues wish me luck
enjoynlife2
welcome to iboats.
im guessing your thinking of a single axle but i might be reading it wrong but it shows a double axle at the least weight of 4500lbs
but i do thank you for your input i let u no for sure when i contact shorelandr i have a 800 num. For them thanks again
tractoman
I think the 4500 lb figure is the gvwr of the trailer with boat on it. It does not weigh 4500 lbs. I'd guess in the 1100-1300 lb range.
enjoynlife2
i beleave your right because i didnt read the plate right . it shows at 14 inch 6 ply tires at 4500 lbs at gvwr and at dual tandum and single axle also 13inc and 15inch not sure the weight for those tires but the plate give the hole weiht class for those tires so if any one needs to no any class for tires i have in fo for a shorelandr trailer
