Trike rider
Thread starter- Joined
- Aug 13, 2020
- 10
Changed water pump on an alphaone gen2. Drive goes into foward and neutral. When in reverse it only clicks
Thanks for the reply. Testing by had. When in reverse it cicks both ways. I will check out the Merc section
Are you testing it with the motor running or turning the prop by hand?
If turning the prop by hand then it normally clicks one way when in reverse and clicks the other way when in forward.
Did you have the gear selector in forward when you removed the drive?
you might get a mod to move this to the mercuriser section.
