shifting problem
ekern68
have a 1975 merc 402 40hp with mercontrol. on the mercontrol shifter, reverse and forward are backwards.(shifter back= forward) have had it apart but cant figure out how to fix it. boat works fine like it is but i'm one of those guys who wants everything to be the way it should be. HELP!!!!!!
Re: shifting problem
usually that is the result of someone installing the gearcase back on the midsection, with the shift rod in the wrong position. Did you have it apart?
ekern68
no havent had motor apart just mercontrol. it was backwards when i bought it.
OK, Remove wrap cowling and Observe shift slide. Move MerControl from neutral to forward. Shift slide should move to front of motor. If it does, and motor shifts into reverse, trouble is in motor. If shift slide moves backward, trouble is in control box.
Wingedwheel
Typically thats a problem that occurs when the LU is dropped for whatever reason and the shift cam is turned 180 out and re-installed. You may have to remove your LU and return it to the correct position.
