well I tried manually moving both the throttle while shifting and was able to but still pretty hard. However if I remove both the throttle and the shift cable from the motor they both move smooth, however I do feel like our throttle lever has ever had the range that it's really suppose to as I feel like it doesn't really move all that far. Therefore I think the cables are actually fine and I'm just wondering if all the cable simply just need adjustment. I did also notice a grease fitting inside the shift lever on the motor so I did grease that and that seemed to help the forward movement decently however going into reverse is still not good and I still don't feel like forward is as smooth as it should be comparing to other boats I've driven. In fact I was never actually able to put the motor in reverse by hand....
do you think a simple cable adjustment by a shop would be worth a try or are we still looking at another possible cause?
