Shift shaft does not go out of adjustment by itself.---------Was the lower unit off for maintenance ?----Was powerhead off ?-----Have you drained / looked at the gear oil ?
The gear oil was real dirty, no metal grinding pieces. I did take off the remote. It does shift into gear. The problem is when the motor has a load. It jumps out in reverse and drive gear.
It normally does not jump out of reverse.---So something is wrong.--Does the shift cable have a lot of play when you push / pull on the motor end of it ?----And is this a problem that showed up suddenly on both forward and reverse ?--Was there water in this gear box at any time in the past ?
I got the boat at the end of last summer. It ran great about 3 time on the lake. The 4 time is when it started all of a sudden. The cable seem nice and Tite. To be honest I'm not sure water got into the gear box. My thought was to change the gears and clutch dog.
