Shift shaft problems!
ssand746
Hello,
I have been dealing with replacing an impeller on a 650 mercury 1967. When I took off the lower unit, the shift shaft stuck in the upper part of the motor, and poped out of the lower unit. I tried reinstalling it anyway after putting in the new impeller, but all I get is forward. The instructions I have say to turn the propeller counter clockwise while turning the shift shaft clockwise. I decieded to take a part a parts motor of mine and put that shift shaft in the lower unit to try to line things up correctly by instructions. Well... When I put the shift shaft in the lower unit I am trying to install, all it does is spin, no mater how far in it is. When the shift shaft is removed from the lower unit, does this creat a problem internally? Any ideas on how to remove the shift shaft that is stuck in the upper part of the motor? Thanks for any help (see picture to understand). Steve
Laddies
Banned
Re: Shift shaft problems!
The chances of reinstalling the shaft with out removing the carrier are slim at best. When the shaft came out the spring in the prop shaft shoved the shift cam into the front of the bullet and because fwd. is default the unit is in fwd. gear and with the cam gone it will not shift.
