Shift Rod Seal Removal Tool
1946Zephyr
Anyone know where I can find one of these? It's for removing the shift rod seal bushings, for the older OMC lower units. I could make one, but the shop I work in doesn't have a lathe. So, I need to buy one.:cool:
backyard mechanic
Re: Shift Rod Seal Removal Tool
Never had one... I always improvised one out of old shaft material. I didn't have a lathe either, just a good grinder to make the end work for me. :rolleyes:
F_R
You can still get them from Evinrude dealers. OR....check your PMs.
EDIT: Well, I tried to go through the proper channels, but the PM system isn't working for some reason. I wanted to tell you that I make those tools. Mine are better than the factory one and less money. Contact me if you are interested. If you can get the PM to work, that is.
ezeke
If you right click the username and select "open in new tab", you can access the PM function.
stevenj
I made one from 5/16 steel rod,with a file and a drill press, then went the rout of F_R's, much better than mine.
F_R
Thanks. I was left clicking on the username, then "send a private massage". Wonder why that doesn't work?? Oh well, your method does work, so all is well.
bktheking
It used to up until a month or so ago.
Mas
Any pics?
Mas
QC
We are aware of the PM and Profile pull down menu issues and have been trying to get it worked out. Stay tuned. Another way to create PMs is to click the Private Messages button, and then "Send New Message". You have to type in the Username with this method.
