Hello all. Does anyone know the height for the shift rod linkage for the 2000 Johnson 70 outboard? Model # J70PLSIS, manufactured in 10/2000.
I changed the water pump assembly, and I am certain that I spun the linkage when it was disconnected, which I later learned was a no-no. Now, the gears are not shifting as they should (neutral-prop spins; control forward-only moves slightly forward).
I want to take it all apart and be sure that the linkage is the correct height. It seems like it needs to get longer.
Thanks!
Thanks!
