Shift Rod Adjustment 89 Yamaha 30 ELF 2 stroke
hslobo
Im replacing the water pump in my 89 yamaha 30 ELF and I need to know how to adjust the shifter rod so it engages the clutch dog properly. There is a locking nut just under the hexagonal barrel nut. I had to back the hex barrel nut off to disconnect so I could drop the lower unit. Now that I need to replace the lower unit, Im not sure how many threads I need to leave showing in order to have the shifter work properly. Any help would be greatly appreciated.
jmoore73
Re: Shift Rod Adjustment 89 Yamaha 30 ELF 2 stroke
My seloc manual for my 89 40 hp says at least 5 threads.
Joel
hslobo
Thanks Joel I'll give that a try appreciate the response
