FliesAndFloats
Thread starter- Joined
- Sep 6, 2015
- 30
I have an issue with my engine (5.0MPI w/ Alpha One gen 2) quitting when going into and coming out of gear. I can see the shift interrupter engaging when I put the throttle into gear. I've been chasing the engine quitting issue since I bought the boat two years ago. I had the outdrive resealed a few months ago and requested that the mechanic inspect the lower shift cable. He said it seemed relatively new and moved freely. However, today after discovering the shift interrupter lever moving when putting the drive into gear, I removed the lower shift cable and moved the sleeve at the end of it by hand and found it very stiff to move. I assume that it should move very freely and this stiffness is what's causing the shift interrupter to engage. It looked like somebody used some sort of grease on the end of it that gummed it up. Does this sound like something I should try and clean up with solvent and WD40 or something or does it sound like my lower shift cable may, in fact, need to be replaced?
