ohio river rat in KY
Thread starter- Joined
- Feb 10, 2010
- 104
its on a 83 120 mec. just redone transome and all, so just put all back together and took it out for a water test leak, well it leaked:facepalm: in water looked like shift bellow cause moved it and would not leak as bad, well got home and found a hole in the shift bellow.... now can i replace it without pulling the whole outdrive again will the shift cable pull through or do i got to pull it all again ???
