Whats the correct shift shaft height on a 1993 short shaft V6?
B Barry Beachum Cadet Joined Nov 21, 2020 Messages 7 Nov 21, 2020 #1 Whats the correct shift shaft height on a 1993 short shaft V6?
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 39,315 Nov 21, 2020 #2 Need to post model # ----Not all V-6 motors are the same !!
B Barry Beachum Cadet Joined Nov 21, 2020 Messages 7 Nov 21, 2020 #3 Its a short shaft evinrude venom
B Barry Beachum Cadet Joined Nov 21, 2020 Messages 7 Nov 21, 2020 #5 Thanks....going over someone else's work on a used lower unit ...need to pull apart see What's up....
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 39,315 Nov 21, 2020 #6 Not all driveshaft lengths are the same either.
B Barry Beachum Cadet Joined Nov 21, 2020 Messages 7 Nov 21, 2020 #7 Right...no it's a used lower unit that someone installed and its just is getting reverse and the cable is as the end of adjustment ..think the shift cradle is bent or broken because 21 15/16 is not working...going over some ill work by someone else
R racerone Supreme Mariner Joined Dec 28, 2013 Messages 39,315 Nov 21, 2020 #8 Just take it apart.----Post pictures of the parts.----I don't think a shift cradle can bend on these !
B Barry Beachum Cadet Joined Nov 21, 2020 Messages 7 Nov 21, 2020 #9 I got to gut it anyway check clutch dog and reverse and install a nose cone and do a seal kit
B Barry Beachum Cadet Joined Nov 21, 2020 Messages 7 Nov 21, 2020 #10 Thanks for the info...thought I was loosing it.... Probably am just don't know it..
