Sevylor HF 280 Fish Hunter and Sevylor Trolling Motor Problem
dobbs571
Re: Sevylor HF 280 Fish Hunter and Sevylor Trolling Motor Problem
here are some more pics of the floor and stuff I have done.love the FH360 for what I use it for cant beat it . Have put it thru some ruff spots and no ploblems .
dobbs571
NO look at it again its .09 NOT 9 LBS IT WILL SPLIT EVERY SEAM. you may get 1.5 lbs in it but thats verry hi I have an email on here some where from the co that say how much do a search but DONT PUT 9 LBS IN IT.If you try it wait till the 4th of July should add some good sound to the firework display
andmot
There are ropes and 4 eyelets on the floor of my FH360.....do I just set the wood floor directly on top of these eyelets? Is there any risk to damaging the inflatable floor compartment from the wood floor constantly pressing on these eyelets?
Also i've heard different things about how to install and inflate the boat around the wood floor - the most common method seems to be to inflat the floor fully and only partially inflat the inner chamber, then install the floor, then finish inflating the inner chamber and then the rest of the chambers.
So with the wood floor in place, does the inflatable floor chamber need to be fully inflated?
CopperFox
I have a newer HF 360 and it has 6 eyelets on the floor. I made my wood floor and using a Dremmel tool, made scoops in the bottom of the floor boards to lessen the pressure on the eyelets. To get their location I put chalk on the eyelets and then inserted the floor boards and put pressure on the floor boards. To be sure there is still some pressure on these spots but it is better than without this modification. I have heard that the factory floorboards are designed to go right on top without and indentations.
I essentially install the floorboards the way you say but can inflate my inner chamber fully to start. Depending on the size of your specific floor boards, this may or may not be possible.
From experience, I would recommend that the floor be fully inflated. This adds rigidity to the boat so it handles better and it also makes your floor more stable.
andmot
Thanks Copper, mine also has 6 eyelets...oops.
I'm thinking of taking my measurements with the boat fully inflated. I've read lots of other people who say to do it deflated, but my thinking is that if I take the measurements on the inside of the boat and right up against the sidewall I would get a better fit. I plan on installing some foam insulation around the edges which would help to snug it in place.
I just don't want to put too much stress on the inner chamber by having such a tight fit with the floor.
Thoughts?
andmot
Copper - it soudns like your floor more or less "rests" on top of the floor, as opposed to some that seem to be slightly "wedged" between the floor and the sidewall.....accurate?
So do you inflate your floor chamber AND sidewall first, then lay the wood floor in? Or do you do the floor chamber, wood floor, then sidewall? Sorry for all the questions...once I get an understanding of the best way to lay the finished floor in place, I can work backwards to come up with how I want to take my measurements.
CopperFox
I may be able to help you significantly. There is a thread on here, started by Devil_Inside, on January 9 2012 that you should easily be able to find searching just the 2 words: Template Sevylor. In there, with a number of others, I detail my efforts to make a floor. Because there seemed to be a need, I also photographed my 2 floor board pieces and showed widths, every 4 inches from bow to stern. You can see what the final product looks like to get an idea of whether this is where you'd like to head.
My 2 boards are not attached at all and sit in front of and behind the middle pair of eyelets. Also, I did not put any foam around the outer edge. I may end up regretting this, but so far there seems no need. I'm not sure but don't think the factory ones have anything other than rounded wood edges. Feedback from others indicates the boat measurements aren't identical from boat to boat, so you may want to make your floor 0.5"-1.0" wider everywhere, roughly sand the edges and try installing it. If the fit needs adjusting, you can always take some off and then do a final rounding of the edges.
Measurements taken when the boat is deflated will be too big because when inflated, the floor rises to leave a drainage channel around the edges. The inflated inner chamber covers most of this space so unless the wood floor edges can bend down, they will never reach that outer edge of the inflated floor.
My boards fit snugly just under the bottom curve of the inner chamber. My seats then get attached to the floor boards and it is only this snugness that keeps the boards, seats and me, in the boat, so it is quite tight. I think it fits your 'wedged' explaination above. I fully inflate the inner chamber (#1), then the floor (#2), and then the 2 bottom stabelizing tubes, as they advise. I then carefully wedge in the floor boards. It is inflation of the outer chamber that really puts pressure on the inner chamber and makes the floor fit solidly in place.
Have a look at that thread and if you have any other questions, don't hesitate. I could also post new photos if some other angle might help. The only changes I've made since those were taken is to 1. finish a board on the back that I use to spread out my tackle, powerbait, pliers, etc. so they can be readily reached and to 2. put a rubber floor mat over the space where the 2 boards meet.
uragon
I have the patterns that were sent to me of the FH360 floor boards if some one need a copy of them send me you address so i can see what it would cost to send them .I can trace them on craft paper so would be a little lighter . Shouldnt be much just standard mail.
I really need it, here is my address 1146 W. McCormick St. Wichita KS 67213. Thanks!
