Setup single throttle on 1985 Capri
JAL51974
Need help with original equip throttle/shifter. Took it apart to recover the side with vinyl now cannot fit back together. All ideas welcome. See pics in my post on steering and controls forum page in iboats. Thx. Joe
JAL51974
Finally figured it out. Watched how the cables operated from the top while moving the handle F-N-R. I must have moved the shift control while it was disconnected because the position of the cables was off. Once I saw how they moved versus how they should move at full throttle I could set them up correctly so that N was at the center position. Everything worked fine and it started right up after that adjustment. It's all cleaned and fresh grease should last a long time now.
