Setting the timing
brian3127
I have a 1972-1977 mercruiser 3.0. Serial number 4920382
I have seen on YouTube that you have to put the engine in base mode to set the timing.
My mercruiser service manual tells me to run the engine at idle and set it to 6 degrees btdc.
What years did they change it
Ayuh,..... Loonnngggg after when yers was built,.......
brian3127
The engine I have does not have points.
Do I still set it to 6* btdc
achris
More fish than mountain goat
That's a 1978 engine, and it'll have points.
Set the points at 22 thou, then the timing to 6 BTDC. (Don't believe everything you see on youtube, there is no 'base timing mode' for this engine.)
Chris......
brian3127
No points there is an ignition module
achris
Interesting. Maybe someone has changed the distributor over for a later model. ???
This your timing procedure and setting. (1 degree BTDC)
brian3127
That’s why I’m confused
The engine is in the process of getting rebuilt and I want to make sure it’s set right.
About $1000 in work at the machine shop plus parts. Me and my son are putting together. So I’m wondering
Scott06
Some one added a delco est kit to it , common upgrade that was also used by merc and volvo penta over the years. Chris has steered you right on how to set it make sure you can measure the total advance with an advance timing light or put a timing tape on the balancer
kenny nunez
Make sure that the machine shop replaces the bushing in the block for the lower distributor shaft above the oil pump.
yes, that under $10 part wears. its also available at any NAPA
