Setting base timing on Prestolite distributor
banderberg
Good morning, I want to check/set the timing on my Mercruiser 3.0L. It has the conventional ignition (as opposed to EST). The distributor is Prestolite IBM 7026. The videos I have found on YouTube all show EST distributors and they have a shunt at the base of the distributor where you jump two wires to put the engine into base timing mode. The Prestolite distributor does not, as far as I can tell, have such a thing. I'm looking for information on how to put the engine into base timing mode with the Prestolite distributor that's on my engine. Thanks!
