Servicing my trailer bearings
Lou C
Ok, so I'm re thinking what little I know about these bearing systems. I just watched a you tube from Rockwell showing how their system works. I do have a zert on my spindles so I assume I have a posi lube system. According to the video, to repack the bearings on the hub you slowly squeeze grease into the system until you have clean grease exiting around the castle nut and everything should be good! ?? I could do that right where the boat sits with a pile of rags and a grease gun? I would check those rear seals to make sure they have not been leaking. This company, in the display they had, there was only a rear seal and then the cap with the rubber piece you can pop out to get to the zert. I'm sure the old school will be to tare it down...
Jack up the wheel on that side and spin the wheel while pumping in grease….
rickasbury
Master Chief Petty Officer
For the most part yes, than take your finger and dig out all the grease around the castle nut and put the seal back on. Your digging most of the grease out because heat will build pressure and if no grease is removed it will push the seal out, it needs a little air space
I know there is a seal in the rear but I don't think there is one in the front?
Jeff J
The dust cap or bearing buddy provides the seal on the front. That’s why those rubber pieces need replaced on the caps used with axles having zerk fittings when they deteriorate or tear. I just install standard caps since I don’t use the zerk fittings
rickasbury
Thanks for all the input, I know enough to be real dangerous! I'll bring it home, inspect those inner seals first. If they look good I'll go to pumping. If a seal is bad then obviously that wheel comes apart but otherwise I'm going to use the posi lube system and see how that works out....
Thanks Again, I appreciate all the input!
Rick
