rickasbury
Ensign
Thread starter- Joined
- Jul 13, 2011
- 913
I have it all cleaned up ready to install my new parts and will get pictures of all ready to install with new pads.
Lol,,sorry...It all makes sense now . . .![]()
With a trailer that heavy and 10 years between services, I'd be more concerned about water intrusion than mileage too. I'd have new bearings, races, and seals ready for all four hubs rather than counting on a simple repack. Lint-free shop towels are a better choice than regular rags, and I'd use a quality water-resistant marine wheel bearing grease. Check the spindle surfaces carefully for pitting, especially where the bearings and seals sit. If there's significant damage, I wouldn't risk towing it until it's addressed. Do you know what brand of axles are on the trailer? That should help narrow down the correct parts.I have a 10k tandem axle trailer I need to service the bearings. I did this when we first bought the boat 10 years ago - which sounds alarming but that's probably 2500 miles tops. The water is more the concerns than the miles.
I did it the one time having never done it before. I'm bringing the boat home which draws the ire of the city so I need to do this like a Nascar pit stop.
I have a temp gun and I keep an eye on the hub temps even on the short runs. I have one that is always about 20 degrees hotter.
I saw one guy on you tube who said the red shop rags should not be use as threads can get on the bearing surfaces..not sure what I should be using.
I do not know any of the bearing or seal numbers. That will be the first thing I get and check with my local shop for inventory. The one that is running hot I for sure will replace, I'd like to have a second set on hand plus replace the seals.
If I have any pitting or rust on the spindle or seal surface, what should I clean that up with? What grit paper can I use?
Clean parts with brake cleaner? How many cans for 4 hubs?
How many tubes of grease and what kind?
Type of rags?
I'm also doing this on asphalt in front of my house. I'll put a tarp down, I have buckets I can spray into and will find something to catch fluid from the spindles.
I'll look at some you tubes on hand packing the bearings..I see contraptions available to press the grease through consistently but I have not priced them.
The boat will be on the trailer- but another goal would be to replace the carpet on the bunks - is that special material? What is used to attach it? I should ve able to do that at the ramp after I slide the boat in the water quickly? That I will do later but want to line up what I need.
Thanks! I need to complete in 2 days max. If I find something that needs additional repair, that will be a come back to or park it if its not safe.
As far as I got on the bearings was to use the spindle zerk to push grease through bearings. The hub seemed to be nice and full- some disclored old grease came out but I did not see any water.the rear seals seemed good so I did not pull the wheels apart at this time. I had the calipers off as well as the wheels to be able turn the hub while I was greasing- none of them had any play, turned freely so I'm concentrating on the breakes. I will add a hub tare down. All my rebuiimlt brakes (3) and the new one...while each line disconnected pumped fresh fluid to clean the system. Should be able to get them bled in the am unless this sudden deep freeze we are in sticks around..With a trailer that heavy and 10 years between services, I'd be more concerned about water intrusion than mileage too. I'd have new bearings, races, and seals ready for all four hubs rather than counting on a simple repack. Lint-free shop towels are a better choice than regular rags, and I'd use a quality water-resistant marine wheel bearing grease. Check the spindle surfaces carefully for pitting, especially where the bearings and seals sit. If there's significant damage, I wouldn't risk towing it until it's addressed. Do you know what brand of axles are on the trailer? That should help narrow down the correct parts.
Not Greek zerk, grease zerk!So...talked to my buddy chat...chat gbt and I would have never thought of it..local hardware store for a Greek zerk, installed where the inlet to the brake line is...i left all the liquid I sprayed in there...starting pumping...couple of pumps more...some pops and walah!
agreed, even the so-called bearing packing tools don't really do a good job. Just get a nice pair of nibrile gloves and a clean work area and go at it.Hand pack the bearings...don't use the zerk. When installing new bearings, remove all the grease, clean the hubs and hand pack ONLY!
I really didn't think I had any pictures worthy of posting...the rebuilt caliper looks the same with new parts so nothing to update. I did make sure to buy specific grease for the slide pins- I for sure had a bum steer from someone on that who recommended an aluminum anti seize permatex crap which turns into a real mess. I put some also on studs for one wheel and may have to put new lug posts as i have one lug I can't get back on...Got more pictures to share?![]()
Thos is not a bearing buddy type zerk as it pumps the grease from the back bearing forward not just filling the hub.Hand pack the bearings...don't use the zerk. When installing new bearings, remove all the grease, clean the hubs and hand pack ONLY!
I understand that. Do not use the LAZ-Lube system.Thos is not a bearing buddy type zerk as it pumps the grease from the back bearing forward not just filling the hub.
LOL...you dunk your trailer twice a year!I saw his vid on this and many of his others, but I stand by what I said, 22 years of use with this system, and I have not had that happen. And the trailer gets greased about 2x a year. I just do it the way you're supposed to. Don't know why others are having failures, but maybe it has to do with the quality of the grease seals you use.
Another point not mentioned:
when you remove the bearings, hand clean and hand pack there is always a chance of getting a bit of grit or something in the bearings, but with the easy lube/spindle lube, not so. JUST DO IT THE WAY IT SAYS!
Never had water either in this system. And being in 100% salt water for sure I'd be having problems if that was the case.
Thanks, I'll check it out-I understand that. Do not use the LAZ-Lube system.
It also sounds like you are relying on that system to actually pack your bearings which is a horrible mistake.
There is a trailer guy called Trailer Smith on YouTube. He NEVER recommends using that system. He does trailer repair for a living.
Thanks for the comment. Can you explain your process of this?I saw his vid on this and many of his others, but I stand by what I said, 22 years of use with this system, and I have not had that happen. And the trailer gets greased about 2x a year. I just do it the way you're supposed to. Don't know why others are having failures, but maybe it has to do with the quality of the grease seals you use.
