Service manual question.... i goofed
cdn-pk
Looking for some help / advice.
i recently bought a 1987 Edson Challenger GT with what the previous owner (and I) Thought was a 1987 Johnson 120HP VRO. The mix up came with the fact i could not read the model and serial number off the mounting bracket.
So i ordered, and just received the J120TLCUR manual from searayman13 along with a parts catalog.
now yesterday i was at the cottage and found the following info stamped on a frost plug:
CJ120TLCDC
G7149080
i am assuming the first is the model and "CD" says it's a 1986. The second must be the serial number. Please correct me if i am wrong.
anyway my question is for those in the "Know"
1) should i just keep and use the 1987 manual? Was there any changes?
2) should i email searayman13 and see if he'll do an exchange ( i see he has the 1986 service manual but no parts catalog)
any advice it most appreciated
hidef
Re: Service manual question.... i goofed
You should be fine with the 1987 service manual. If there were any changes they were minimal. You can always go to http://www.marineengine.com and compare the parts between the two years if you are concerned.
boobie
The 1987 manual will be okay. In 1988 the mtr had some changes.
Rick.
Searayman is a standup guy. I would not hesitate to drop him an email if your inclined. Goof ups happen. Best of luck. Rick.
cdn-pk
Thanks for the quick responses. i emailed searayman, i'll see if he has the 1986's and if he'll swap. if not after leafing through the 1987 manual it's definitly have a year off than none at all.
thanks again guys, will keep you posted.
