Sender electrical problem compounds itself into a few problems, need a hand please
bearer
I am having a frustrating problem replacing the fuel sending unit on the 73 Aztec.
I pretested the ohms on a new marine sending unit before I cut the length of the rod with the float (in specs) and also tested the ohm readings with the sender set loosly in the tank. (It measured 145 ohms half tank). When I fastened it to the tank with the screws the reading dropped to 40 ohms. This reading was without the wires hooked up to the sender. I pulled it back out to double check the readings and it was in spec as long as it wasn't fastened to the tank with the screws. Could this problem be not enough of a ground to the fuel tank?
Now the fun part.
I refastened the unit, hooked up the black to the -- and the pink to the S side. Turned key on and 10 seconds later the key was hot and the # 2 fuse blew out. SFE 14A.
My bilge pump stopped working after the fuse blew. After replacing the blown fuse I pulled each fuse out to double check if any other fuses had blown. All were ok but when I turned the key on to test the switch to the bilge pump, well it worked and the blower motor no longer works.
The + wire on the #2 fuse gets hot still. The wires to the sender at the tank are disconnected. I am guessing I have a dead short relating to the second problem. Then again the short must be in the flow to the fuel guage also.
Anyone have any idea what is going on here?
Boatin Bob
Re: Sender electrical problem compounds itself into a few problems, need a hand pleas
You could have a bad fuel gauge, refer to the sticky at the top of this forum and look at Silvertips generic wiring diagram. You will see that normally 12v is fed to all the gauges from the ignition switch, it goes to first gauge and is daisy chained from there (wired in parallel). It could be your fuel gauge or another, just pull the 12v wire off each gauge one at a time until the that fuse doesn't get hot anymore.
bearer
What about the new fuel sender itself?
What could be causing the ohms to drop to 40 ohms when I attach it to the tank itself? Bear in mind there are no wires from the boat connected when it does this.
D
DJ
Guest
I assume it's a metal tank?
If so, do you have a stray wire touching it somewhere?
How about a metal fuel line (not good) going to the engine?
bearer
The metal fuel line is broken off as a conduit by a rubber fuel line from the copper line to the water separator. I also have a temporary plastic fuel filter with rubber fuel lines in place solving a problem of silicone in the tank itself. I am using the filter to catch silicone that fell in before I purchased the boat. (Boat was not getting fuel to engine) The old sending unit was broken and would not give any OHM reading.
I removed the foam from the top side of the tank already and found only the pink wire, the black wire, and the fuel filler line as well as the breather line. I also isolated the wires from the tank area by pulling them away from the tank and onto the fiberglass deck.
D
DJ
Guest
Glass or Aluminum boat?
bearer
She is a 20 foot fiberglass boat.
littlebookworm
Are you reading 40 ohms with some gas in the tank? That could be a correct reading if the swing arm is not all the way down to empty. If your tank is empty and the readings are wrong, try connecting a temporary ground from your tank to the heavey negative buss bar near the dash. See if that gets your resistance readings where they should be. By the way, if I'm not mistaken, you should have found an additional ground wire going from the tank to the thru-hull filler neck, to prevent static electricity from really ruining your day. Good luck.Hy
bearer
It measured 145 ohms with about half a tank without fastening to the tank and 40 when fastened.
Ok so this opens up another question then.
Should the tank be grounded on its' own or does the ground from the panel act as the tank ground??
Boatin Bob
The tank should have it's ground that always attached (could be a green wire) in addition to the black (ground) you attach at the sender. I'm wondering if the float is touching or binding on the side of the tank causing the float to hang up when you tighten it? 40 ohms would pretty much mean that the tank is full. Whatever that problem is I don't see how it's related your fuse problem especially when you have the wires disconnected.
