sheboyganjohn
- Aug 2, 2005
- 753
I used the Dory about 6 times last year with the self bailing hull openings. Works o.k. but takes on water if everyone goes to that one side and water comes in when going on and off plane. The most annoying is waves sloshing in and out when anchored. The deck is fully sealed so the water coming in is not a safety issue. I do not like water draining into the bilge so I want to keep the openings for storage in the yard to let the deck drain. I am trying to come up with a way to plug them when I am using the boat and then open them when in storage. I was thinking of a using screw in type deck inspection ports. Any other idea's. Changing the size and shape of the opening is not an issue so any idea is possible.
