Securing thru-hull fittings???
mick1973
I'm renovating my 30' Intrepid, however I'm not reinstalling the saltwater washdown system, and the baitwell system. This leaves a total of three holes below the waterline that I won't be needing.
I will be purchasing new bronze thru-hull fittings to replace the old ones. Can I just cap the fittings off with the caps shown or should i add a shut-off valve for extra safety?
Coors
Re: Securing thru-hull fittings???
Caps should work, you can always go back and install whatever, if you need to.
