Re: Seat Removal?
The screws are buried, and I mean buried, in the folds of the vinyl. You have to dig for them with your fingers. HINT: Remove the access panel from the ceiling at the head of the aft berth to see the pointy ends of the screws. Once you find them (Phillips head) back them out. There will also be a few driven into the seat base from inside the cave. They will be hidden in the monkey fur. Once again, feel around, and once you find them, there will be a tiny slit in the fur (sorry if this sounds x rated) and you can take the screws out. That should do it. I used to have the same boat, and it took a while to find them all, but I got 'em and the seat came out.
