Seat Removal 2004 Ranger 195VS
264Douglas
I need to remove the driver's and passagner seats on my 2004 Ranger 195VS Bass Boat to replace a float in the fuel tank that is stuck. I can't seem to find a way to remove the seats. Can anybody tell me how to remove them? Any suggestions would be greatly appreciated.
bkwapisz
Re: Seat Removal 2004 Ranger 195VS
Can you post a couple pics?
264Douglas
Yes. I have photos from several different angles but am having trouble uploading them from my computer. I keep getting a message that the upload failed. I will keep trying and thanks for your respose. If you have any ideas, let me know how I might be able to remove the seats. There must be a trick to removal somehow as I don't see any bolts to loosen and can't find a way to get under the seats to the fuel tank. Thanks again.
muddyjc
Well 264Douglas, I can't help you on the seat issue, I've got a similar question posted for an earlier model. But, I think I can tell you why you are not able to upload photos. The most likely reason is that the picture files are too large for the forum's guidelines. When you attach files the pop-up panel shows the largest file size that the forum will accept. It also shows the permitted file types, you could be trying to upload a non-supported file type.
If the file is too large you would need to run it through an editor to reduce the resolution to what the forum accepts and/or convert the file type to a supported type.
Regards...
pops
Look at muddyjc's thread right above yours. I think we have answered your question about seat removal.
