Sears (Ted Williams) 7 Hp Inspection
Retired n Bored
Looking for parts & exploded parts view (PDF). I like the unit but lack the knowledge of its innards. Replaced starter rope when I noticed leak in lower unit. Replace gasket & lube then noted it's stuck in drive. Linkage loose or broken. I was told by bro-n-law (owner) it started last time he had it out of storage. Anticipate impeller is toast but can't get lower unit off; linkage stuck somewhere in upper end.
Anybody?
salvageyard saviour
Love that screwdriver handle for the carb adjustment 😣 looks hotwired
When I get home, I'll look for that part diagram. May not be exact year but should work
Does it have forward and reverse?
brim_buster
One of the easiest motors to work on. Check your private messages
salvageyard saviour
I didn't get home until late last night.
Looks like brim buster got what you needed.
Good luck
